Hi,everyone,
I am creating my advanced bootcopier to boot the specific image from the EPCS64 stored with two different images. Having read the document "Alternative Nios II Boot Methods",I downloaded the hardware and software design example. When I changed the hardware design in my SOPC build system, I can not create my advanced bootcopier. After trying several times, I found that the document "bootcopier_bsp_settings.tcl" is associated with the hardware design . So I think it is necessary to modify the "bootcopier_bsp_settings.tcl" . I am using Quartus12.0, my SOPC system includes Cpu, system ID, Jtag uart, EPCS controller, SRAM, PLL,Onchip_RAM, pio_led. I used the niosII command shell to build my advanced bootcopier and software project. But I donnot konw How to modify it .Can anybody help me ,or give me some document about this? Thank you very much! Sincerely Luke.Link Copied
--- Quote Start --- Hi,everyone, I am creating my advanced bootcopier to boot the specific image from the EPCS64 stored with two different images. Having read the document "Alternative Nios II Boot Methods",I downloaded the hardware and software design example. When I changed the hardware design in my SOPC build system, I can not create my advanced bootcopier. After trying several times, I found that the document "bootcopier_bsp_settings.tcl" is associated with the hardware design . So I think it is necessary to modify the "bootcopier_bsp_settings.tcl" . I am using Quartus12.0, my SOPC system includes Cpu, system ID, Jtag uart, EPCS controller, SRAM, PLL,Onchip_RAM, pio_led. I used the niosII command shell to build my advanced bootcopier and software project. But I donnot konw How to modify it .Can anybody help me ,or give me some document about this? Thank you very much! Sincerely Luke. --- Quote End --- :confused::confused: Is my question not clear?
