21615 Discussions
How to put hex fire in-system ram
Hi, everyone. I have generate a one-port RAM, how can I put the test program hex fire in this ram? And do I need to initialise this ram? And when I use the in-system memory content edit, it shows there is no instances in-system memory? what does this mean? how to solve this? Thank you!
When you make your ram in megawizard it will ask you if you got mif or hex file to initialise then just navigate there.
The in system mem editor is activated only if ask megawizard that you want to run it. again it is an option in some devices/some rams when you run megawizard.
