Programmable Devices
21611 Discussions
How to set content in a memory
with a mif or hex you can pre set a memory content
Thanks Alexandre,
I've checked your suggestion, but what if I've 2 memories?
Apparently, mif and hex just assign width and depth.
How to appoint mif A and mif B?
Besides that,
I've RAM infer, build in my project. Can I save a data on it in the same way with mif and hex??
module SRAM_INFERS(CLK, WA, WE, DI, RA, DO, RA0, DO0, RA1, DO1, RA2, DO2, RA3, DO3); input CLK; /* 256 bit Write port */ input WE; input WA; input DI; /* 256 bit Read port */ input RA; input DO; /* 8 bit Read ports */ input RA0, RA1; input RA2, RA3; output DO0, DO1; output DO2, DO3; wire DO0_tmp, DO1_tmp, DO2_tmp, DO3_tmp, DO_tmp; reg DO0, DO1; reg DO2, DO3; /* Memory */ reg Mem ; always @(posedge CLK) begin if(WE) Mem = DI; end assign DO_tmp = Mem; assign DO0_tmp = Mem]; assign DO1_tmp = Mem]; assign DO2_tmp = Mem]; assign DO3_tmp = Mem]; /* Subfield Extraction for 8 bit Read */ always @(DO0_tmp or RA0) begin casex(RA0) 5'b11111 : DO0 = DO0_tmp; 5'b11110 : DO0 = DO0_tmp; 5'b11101 : DO0 = DO0_tmp; 5'b11100 : DO0 = DO0_tmp; 5'b11011 : DO0 = DO0_tmp; . . . . end endmodule
regards,
That won't infer RAM due to asynchronous read.
That said, you can initialize the RAM contents with a "inital" block and a $readmem function to read data from a file.
Another way is to use a ATLSYNCRAM function and point the INIT_FILE parameter to a .MIF or .HEX file.
use the mega wizard to create the memory.
