21602 Discussions
How to setup 4ch 25g ethernet in one bank in stratix 10 L-tile?
PHuan25
I had setup 2ch 25g ethernet in one bank in stratix 10 successfully. But when I want to setup 4ch, it always recognized 2ch only.
I follow the spec. to config two ATX PLL ip for Main and Clock Buffer. The compilation is passed. But I always only can access the 2ch on Main PLL, the other 2ch on Clock Buffer PLL can not access.
Deshi_Intel
Hi Phuan25,
You can generate 25G 4 channels example design directly from 25G IP GUI. Refer to attachment.
From the example design, you can see 25G IP is using 2 ATX PLL to clock 4 25G channels. (one ATX PLL to clock 2 25G channels each)
dlim
PHuan32
Dear dlim,
Thanks! I had solved the issue. The root cause is setting the same parameters of these two PLLs.
Phuan25
Deshi_Intel
HI PHuan32,
It's good to know issue is resolved at your side.
dlim
