21602 Discussions
IP starting up stability
I work on cyclone IV FPGA with Quartus 10.1
I have an IP which behaves differently in every starting up of the FPGA.
Is there a safe way of configuring the fpga (with mode erase all of memories and registers)?
or is there any option to activate before compilation?
Could someone help me
NB: I have initialised every signal and every ram
Either Your design doesn't meet timing constrains or the FPGA is broken.
take a look at reset logic, maybe add some synchronizes
thank you for your reply,
All timing constrains are met and the FPGA is not still broken.
I hope, it is something like the reply of "thepancake"
Are You sure You are not generating any metastability sources? E.g. async inputs?
I have checked Mestability report of timeQuest Analyzer but all values are correct
Hi everyone,
I resolve the problem by clearing all RAM and FIFO at power-up reset!
thx
