Programmable Devices
21602 Discussions
Ignoring timing violations
Hello everyone,
I need help in setting some timing constraints. I have high frequency data lines which are constrained with 275MHz clock. Also, I have another input signals which work with the same frequency but are not crucial for the design and the constraints can be violated. How shall I set the fitter to ignore optimization of these lines and classic timing analyzer to disable warnings ?
Best Regards
Joel
Is maybe the "Cut Timing Path" setting appropriate in this case ?
