Im curious why
Noone had any advice about running Cyclone II based boards off rechargeable batteries? Is there something I dont know where it's a bad idea?
If you want to go with an easy to use switcher, you can use the point of load modules. One made for FPGA's is the muRata MPDTY01 www.murata.com/power/short/f07e1.pdf . A whole range of options for Altera FPGA's is found at
www.murata.com/power/fpga/altera/index.html
including a power supply design reference guild for Altera FPGAs.
--- Quote Start ---
If you want to learn a little more about cyclone devices for battery powered applications, you may want to try to look at this board that linear tech and arrow put together:
http://www.fpgajournal.com/articles_2007/20070904_proof.htm
this is a nice little write up from fpga journal.
good luck,
guano
--- Quote End ---
Thanks for the pointer. Does anymore here happen to know exactly which device is used for the CellularRAM? I'm particularly curious whether they picked a muxed Addr/Data version.
Tommy
The CellularRam utilized in the LPRP is referenced by the hyperlink below.
It has separate address, data and control busses. It can handle about 135 Mbyte/sec transfer rate and automatically defaults to < 200uW of powerdraw when it is not being accessed. It has both a simple assynchronous (SRAM like) interface or a higher performance burst mode interface. The LPRP uses it in burst mode.
http://www.micron.com/products/partdetail?part=mt45w4mw16bcgb-701%20wt (http://www.micron.com/products/partdetail?part=mt45w4mw16bcgb-701%20wt)
Thanks (again) Skravats. I actually attended the Arrow event and have the LPRP in hand.
While I have issues with the Arrow event, the LPRP board is pretty cool. Had the LPRP been 1/3 - 1/4th the size, it could have been immediately useful besides just being a dev kit. Hopefully we'll see more battery power dev kits in future.
I want you to know I've returned to this project and still intend to finish it. I still appreciate all your good advice, I am now working on getting one of those small text LCDs to work with my project before anything else, then I will return to this problem, thanks for your help.
