21615 Discussions
Impossible to modify the size of an expression in the DS-5 AE Debbuger
I would like to show in the expression tab a word in memory (4bytes).
The address of the word is made from a label + an offset.
When I show it in the expression tab I can only see one byte. (See attached file)
What can I do to specify the size of the data?
Thanks for your help.
Jerome
The solution is to use this syntaxe :
*((unsigned int *) memory_address)
Jerome
