Programmable Devices
21607 Discussions
Improving my NIOS II code to improve speed.
HI, This is my NIOS II code but I think it is not that great becasue it cannot deal with data >200 Hz.
Does anyone have any idea for changes to improve the speed?
Thank you very much in advance, do you not know how much this is appericated.
# include <stdio.h># include <string.h># include <ctype.h>
# include <stdio.h>
/* Nichestack definitions */# include "ipport.h"# include "tcpport.h"# include "libport.h"# include "osport.h"# include "altera_avalon_pio_regs.h"# include "myprogram.h"# include "command.h"
int OpenSocket(int tcpip_port)
int fd_listen;
struct sockaddr_in addr;
if ((fd_listen = socket(PF_INET, SOCK_STREAM, 0)) < 0)
return TCPERR1;
addr.sin_family = AF_INET;
addr.sin_port = htons(tcpip_port);
addr.sin_addr.s_addr = INADDR_ANY;
if ((bind(fd_listen,(struct sockaddr *)&addr,sizeof(addr))) < 0)
return TCPERR2;
if ((listen(fd_listen,1)) < 0)
return TCPERR3;
return fd_listen;
void srv_tcpip()
int sock, fd_client, fd_tmp, nfds, status, idx;
int len, retval, n_read;
fd_set rset, wset, rset_, wset_;
struct sockaddr_in incoming_addr;
alt_u8 buf[255];
alt_u32 in_data;
int rdy = 0, rdy_old = 0;
if((sock = OpenSocket(DATA_PORT)) < 0) {
fprintf(stderr, "srv_tcpip: unable to open socket\n");
return;
FD_ZERO(&rset);
FD_ZERO(&wset);
FD_SET(sock, &rset);
nfds = sock+1;
fd_client = -1;
for(;;) {
wset_ = wset; rset_ = rset;
retval = select(nfds, &rset_, &wset_, NULL, NULL);
if(retval < 0) {fprintf(stderr, "srv_tcpip: failure on select\n"); return;}
if(FD_ISSET(sock, &rset_)) {
len = sizeof(incoming_addr);
fd_tmp = accept(sock, (struct sockaddr*)&incoming_addr, &len);
if(fd_client == -1) {
fd_client = fd_tmp;
FD_SET(fd_client, &rset);
FD_SET(fd_client, &wset);
nfds = fd_client+1;
} else {
close(fd_tmp);
} else if(fd_client != -1 && FD_ISSET(fd_client, &rset_)) {
n_read = recv(fd_client, buf, 80, 0);
if(n_read <= 0) {
close(fd_client);
FD_CLR(fd_client, &rset);
FD_CLR(fd_client, &wset);
nfds = sock + 1;
fd_client = -1;
} else if(fd_client != -1 && FD_ISSET(fd_client, &wset_)) {
//IOWR_ALTERA_AVALON_PIO_DATA(RRDY_PIO_BASE, 1);
rdy = IORD_ALTERA_AVALON_PIO_DATA(EMPTY_PIO_BASE);
if(rdy_old != rdy) {
rdy_old = rdy;
if(rdy == 0) {
in_data = IORD_ALTERA_AVALON_PIO_DATA(READ_PIO_BASE);
status = send(fd_client, (void *)&in_data, 4, 0);
continue;
/* Command thread: handle commands from tcpip client */
void cmd_tcpip()
int sock, fd_client, fd_tmp, nfds, status;
alt_u8 buf[256];
if((sock = OpenSocket(CMD_PORT)) < 0) {
fprintf(stderr, "cmd_tcpip: unable to open socket\n");
return;
FD_ZERO(&rset);
FD_ZERO(&wset);
nfds = sock+1;
fd_client = -1;
for(;;) {
if(retval < 0) {fprintf(stderr, "cmd_tcpip: failure on select\n"); return;}
fd_client = fd_tmp;
nfds = fd_client+1;
} else {
close(fd_tmp);
if(n_read <= 0) {
close(fd_client);
nfds = sock + 1;
fd_client = -1;
} else {
printf("Received %d bytes\n", n_read);
status = do_cmd(buf);
status = send(fd_client, (void *)buf, n_read, 0);
continue;
