21611 Discussions
Inferred RAM Coding
How can we infer the following memory module as RAM instead of register array ?
https://github.com/promach/internal_logic_analyzer/blob/master/rtl/memory_block.v
I have tried to modify, but some inevitable warnings are shown. http://quartushelp.altera.com/14.1/mergedprojects/msgs/msgs/wtdb_analyze_comb_latches.htm
(http://quartushelp.altera.com/14.1/mergedprojects/msgs/msgs/wtdb_analyze_comb_latches.htm) `include "define.v" module memory_block (clk, write_enable, waddr, raddr, data_write, data_read); input clk, write_enable; input waddr; input raddr; input data_write; // data to be written into memory output reg data_read; // data read out from memory reg memory ; always @(*) begin if (write_enable) memory = data_write; end always @(*) begin if (!write_enable) data_read = memory; end endmodule
https://alteraforum.com/forum/attachment.php?attachmentid=14134&stc=1
Probably start by using posedge clk instead of * in the always blocks.
Thanks. I could now infer RAM with https://github.com/promach/internal_logic_analyzer/blob/master/rtl/memory_block.v by using larger MEMORY_SIZE.
