21600 Discussions
Internal Clock HELP
Helloo..
I had a project to do on an Altera Cyclone II board, it's a Digital Calendar. I've completed it successfully but I have a problem with the clock, I have a 27MHz and 50MHz internal clocks, and I need to make the calendar increments a day every 24 hours.. anyone has any idea wut am i supposed to do.. wut I thought abt is that we know the Frequency= 1/Time period..
so if I say : 24hrs * 3600 seconds =86400 .. so the frequency i need in order the calendar turns after 24 hrs is 1/86400 am I right ??
Please I need help ASAP .. :) thnx
a cascade of counters, something like this:
process -- clked on 27MHz if Hz_count /= 27000000-1 then Hz_count <= Hz_count +1; else Hz_count <= 0; if seconds_count /= 59 then seconds_count <= seconds_count + 1; else seconds_count <= 0; if minutes_count /= 59 then minutes_count <= minutes_count + 1; else minute_count <= 0; if hours_count /= 23 then hours_count <= hours_count + 1; else hours_count <= 0; if days_count /= final_day then days_count <= days_count + 1; else days_count <= 1; end if; end if; end if; end if; end if;
Is this pure 100% HDL project OR Nios II project?
It's a pure VHDL .. usually i used to divide the clock to make it faster.. but now i need it slower ..
Then as suggested by others, previous posts, you can divide down MHz to Hz. Then use it has global clock. At Hz frequency, PLL would not work.
