21609 Discussions
VHDL code for PISO shift register using JK
pleasetell me the code for PISO shift register usink JK flip flop..
I have my exama nd i ahve made almost 20 programs, bt i m nt ble to do this one..
please help me with this..
thanks..:) :) :)
FPGAs use D flips and a parallel to serial shift is straightforward:
signal shift_reg : std_logic_vector(7 downto 0);
...on the clk edge:
if load = '1' then
shift_reg <= data_in; -- data_in 8 bits
else
shift_reg <= '0'&shift_reg(7 downto 1);
end if;
data_out <= shift_reg(0); -- data_out one bit
You will need to control the load signal to inject one byte until serilised out.
if you want JK flip then instantiate JK then convert it to D by connecting each data_in bit to J & K with one inverter before k. You are now using structural vhdl to connect up flips just like schematic. No practical sense since the JK is actually made from D in FPGAs - I think.
please give me the code using JK flip flop..
actually it has come in my exams lot of times..
please..
Out of my head:
Instantiate 8 jkff primitives(see quartus help), declare 8 bit signal j,k,Q then connect j,k,Q nodes then on a clked process:
if load = '1' then
J <= data_in;
k <= not data_in;
else
J <= '0'&Q(7 downto 1);
K <= '0'&not Q(7 downto 1);
end if;
data_out <= Q(0);
you will need to double check my indices...
edit: sorry you don't need clked process as clk will be connected direct to clk port of flips.
can u pls elaborate it..
m nt able to understand..
and sorry but i think this is not correct.
--- Quote Start ---
--- Quote End ---
JK flip does not pass data (it is not like D flip), hence I convert it to D flip by inverting k input. if inputs are 01 then output is 0, if inputs are 10 then output is 1, hence it passes data and becomes like D flip.(the logic table may be the other way round, check that please).
When load is high , input is passed to flips. when load is low(and should be low until data is serialised fully) then shift captured data through the pipe of flips with each j/k input pair driven by previous Q output.
Hope this helps. There might be other ways of design please elaborate what could be wrong...
ya i got this all..
but then why do we need to assign an input to K..
as we need J only to produce the output and to shift the bits.
JK flip table says:
j-----k-----Q
0----1-----0 called reset
1----0-----1 called set
0----0-----0
1----1---- inverts Q
so the only way to pass data is using the reset/set cases.
ya i know this table..
thnks..
i just try the program and will give u..
u pls give me ur comments over it..
thnx..
Library IEEE;
Use IEEE.STD_LOGIC_1164.ALL;
Use IEEE.STD_LOGIC_ARITH.ALL;
Entity piso is
Port( D : in std_logic_vector(2 downto 0);
CLK : in std_logic;
Q : inout std_logic_vector(2 downto 0);
QBAR : inout std_logic_vector(2 downto 0));
End piso;
Architecture structural of piso is
Component d_ff is
Port (d,clk : in std_logic;
q,qbar: inout std_logic);
end t_ff;
signal tmp:std_logic_vector:=”010”;
Begin
D<=temp;
Wait for 10 ns;
D2: d_ff portmap (d(2),’1’,q(2)qbar(2));
D1: d_ff portmap(d(1) ,’1’,q(1),qbar(1));
D0: d_ff portmap(d(0),’1’,q(0),qbar(0));
End structural;
please tell me if its fine..
Did you try to compile it?
You have a signal that you define as 'tmp', but then use as 'temp'.
You assign a value to the signal 'D', which is an input
You use the 'wait' statement, that is only valid in a process
You assign '1' to the clocks of your d_ffs, so they will never load any data
This isn't a PISO, it's just 3 D flips in parallel.
You'd better restart from scratch...
First define your input/output ports. The ports you have here aren't right for a PISO.
Then describe what the PISO should do
Then see how J-K flips/flops are instantiated.
Instantiate the flip/flops and write the process to control them.
wadheraswati.... i tried the coding but it seems not working....
Most HDL programmers would use a behavioral description for the shift register. if you're required to use a structural description with individual FFs, sketch a logic diagram on a piece of paper first. Besides the points already mentioned, you didn't connect a clock to the DFF. Not surprizing, the code does nothing.
