I am using MAX10 10M50SAE-144C8GES installed on our board, with Quartus Prime 15.1, programming with USB Blaster rev C.
I was debugging using SignalTap II, modifying the project, compiling and downloading it through the LogicTapII tool. At some point in the project development I got message "Invalid JTAG configuration" and was unable to program the MAX10 chip. I tried to use programmer tool and it shows completion but the MAX10 chip is not actually programmed (the chip doesn't work). I changed both the board and the USB Blaster, got the same result. I tried USB Blaster with Altera 10M08 eval board and simple test project - it works fine through the SignalTapII. I tried to remove the last added module from my project and after few compilation, resetting the programmer, the board and my computer, the MAX10 started working. I put the missing module back and continued my work, tracing the operation. After about 10 traces SignalTapII didn't capture the complete trace (about 25% of the samples) and after I tried to reset the MAX10 chip and download the program I got the same message "Invalid JTAG configuration". Please help! Thank you.Link Copied
Based on your description it sounds like power supply issue. Module that you're referring to might be disrupting the power to MAX10 rendering JTAG failure.
I solved the problem - it is CONF_DONE, pin 138. I used it as an option pin for debugging and when I strapped it to Gnd, the MAX10 chip stopped working. Once the jumper is removed, everything is OK.
In the Quartus dialog Assigments->Device->Device andPinsOptions->General there is a check box "Enable nCONFIG, nSTATUS, and CONF_DONE pins". I understood that by un-checking the check box I will be able to use any of these pins as regular inputs. It turns out that tying CONF_DONE to Gnd prevents the MAX10 device from entering user mode regardless of the state of the check box! The description of the check box in the dialog reads: "Enables major configuration pins, nCONFIG, nSTATUS, and CONF_DONE pin in user mode. If this option is turned off, the nCONFIG, nSTATUS, and CONF_DONE pins are disabled when the device operates in user mode and is available as a user I/O pin." I think there is a bit of ambiguity here because if the CONF_DONE intended to be used as an input and that input is low (tied to Gnd) the part will not enter user mode. I feel it would help users if Altera clarify that.- Mark as New
--- Quote Start --- Based on your description it sounds like power supply issue. Module that you're referring to might be disrupting the power to MAX10 rendering JTAG failure. --- Quote End --- jackyb0i, thank you for you thought. The power supply was OK. It is actually CONF_DONE pin strapping to Gnd.
--- Quote Start --- I solved the problem - it is CONF_DONE, pin 138. I used it as an option pin for debugging and when I strapped it to Gnd, the MAX10 chip stopped working. Once the jumper is removed, everything is OK. In the Quartus dialog Assigments->Device->Device andPinsOptions->General there is a check box "Enable nCONFIG, nSTATUS, and CONF_DONE pins". I understood that by un-checking the check box I will be able to use any of these pins as regular inputs. It turns out that tying CONF_DONE to Gnd prevents the MAX10 device from entering user mode regardless of the state of the check box! The description of the check box in the dialog reads: "Enables major configuration pins, nCONFIG, nSTATUS, and CONF_DONE pin in user mode. If this option is turned off, the nCONFIG, nSTATUS, and CONF_DONE pins are disabled when the device operates in user mode and is available as a user I/O pin." I think there is a bit of ambiguity here because if the CONF_DONE intended to be used as an input and that input is low (tied to Gnd) the part will not enter user mode. I feel it would help users if Altera clarify that. --- Quote End --- Vgelman, The pins are dual purpose and can be used in user mode. But you have to account for what happens before the device can enter user mode: configuration mode. The configuration pins(nconfig, nstatus and conf_done) need to be pulled high for successful configuration. A high CONF_DONE usually signify a successful configuration. The FPGA can't tell if the configuration is successful if the CONF_DONE does not go high. In your case the FPGA will always think that it is still in configuration mode since CONF_DONE is tied to ground. If you want CONF_DONE to be low, you can set it to GPIO low, in which the changes will take effect once you enter user mode. Cheers :)
