Programmable Devices
21615 Discussions
Is the sum signed in LPM_MULT megafunction?
This is a pretty straightforward question - I did not find the answer in the docs:
- Is the sum input vector of an LPM_MULT megafunction signed? Is it only signed if the multiplication is signed?
To my opinion, it makes no difference, if you understand the sum input as signed or unsigned. Generally there's no difference between signed and unsigned add, unless saturation or carry is involved.
Apparently, the sum option has been removed starting with the V8 MegaWizard.
