21615 Discussions
Is there any restriction of using Quartus Prime Eval license?
OZhao1
I plan to generate a Quartus Prime Pro evaluation license. Just wondering if it has any restrictions to use? will it allow users to generate a bitstream file?
Olive
AR_A_Intel
Hello
Welcome to INTEL forum. Per my understanding, During Intel FPGA IP Evaluation
Mode, the Compiler only generates a time-limited device programming file (<project
name>_time_limited.sof) that expires at the time limit.
You only need to purchase a full production license for licensed Intel FPGA IP cores
after you complete hardware testing and are ready to use the IP in production.
Refer for more file:///C:/Users/aabdrahi/Downloads/an320-683502-667093.pdf
OZhao1
BTW, what is the name of this application note (an320-683502-667093.pdf)? I did not find it by searching the file name.
Olive
OZhao1
Thanks a lot for your response!
AR_A_Intel
Hi
You could refer to https://www.intel.com/content/www/us/en/docs/programmable/683502/17-1/an-320-using.html AN 320: Using Intel® FPGA IP Evaluation Mode
AR_A_Intel
I hope all is well. We have not heard from you and I hope that my last note clears up this matter. It is not recommended to keep a Case idle too long without activities. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
OZhao1
Sorry for the late response! Yes, it is clear now, and thanks for your answers!
Olive
