Programmable Devices
21615 Discussions
Issue in Simple Client in Nios2
I am having the simple client in nios2 program which is using the winsock2.h header.
Have included the all w32api files to the project. ( Attached is the client program).
When I try to compile it, its showing me an error in winnt.h and winbase.h files. Below are the error:
/client_bsp/winnt.h:2350:2: error:# error "undefined processor type"
In file included from ../client_bsp/windef.h:253,
from ../client_bsp/windows.h:48,
from ../client_bsp/winsock2.h:22,
from hello_world.c:2:
../client_bsp/winnt.h:2352: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
../client_bsp/winnt.h:2363: error: expected specifier-qualifier-list before 'PCONTEXT'
I believe, I might be missing some files hence the error.
Could you please assist me in this.
Subbu
You can't use winsock or win32 API on a Nios 2 application, they are only available on Windows. You should use standard BSD sockets instead.
Ok Can I get a client program for the nios2. The demo which altera gave is server.
The BSD socket is widely documented. For example you can find here (http://en.wikipedia.org/wiki/bsd_socket) examples for both servers and clients, on both UDP and TCP.
