Programmable Devices
20742 Discussions
JTAG-UART Help Needed
I am trying to establish a link between a PC and NiosII board to print characters on the LCD. I am trying to have a console of something similar on the PC where i can type or enter characters and will be sent to the DE2 board running NiosII and print them on its LCD.
I have found an example that does something similar but there is no input to the board in real time from PC.
__________________________________________________________# include <stdio.h># define JTAG_UART_DATA ((volatile int*) 0x10001000)# define JTAG_UART_CONTROL ((volatile int*) (0x10001000+4))
int main()
unsigned char hwld[] = {'h','e','l','o','\0'};
unsigned char *pOutput;
pOutput = hwld;
while(*pOutput) //strings in C are zero terminated
//if room in output buffer
if((*JTAG_UART_CONTROL)&0xffff0000 )
//then write the next character
*JTAG_UART_DATA = (*pOutput++);
As you can see, "HELLO" is hard-coded. I can see the text being sent to the Altera Monitor Terminal, My question is how can i type this in real time and have the board scan the JTAG-UART over and over again? What program shall i use? Thanks.
One way is to use the GetInputString command. Check out this design example on ALtera's design store: https://cloud.altera.com/devstore/platform/15.0.0/nios-ii-qsys-hello-world-lab/
look under the software directory for the hello_world_hardware_interrupt.c and you can use that as a guide.
that's right... do monitor the incoming receiving byte via GETinputString, and then process the string.
