21615 Discussions
Kindly advise if below part marking match with ALTERA MPN: EPCQ64ASI16N? Please help to share part marking details for this item if available. Thanks.
NYuso
JosephC_Intel
Thanks for re-submit this case in the correct forums.
We appreciate your effort. We will check with internal team about yours concerned.
Will come back to you ASAP.
Joseph
Intel Customer Support
JosephC_Intel
Hi NYuso,
Please refer to below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/pcn/pdn1708.pdf
Joseph
NYuso
Hi Joseph, I cannot find part marking information based on the provided PDN. Kindly confirm if part marking match with ALTERA MPN: EPCQ64ASI16N? Thanks. Thanks and best regards, Najwa
Nooraini_Y_Intel
Hi Najwa,
Please cross check with the supplier that you have bought EPCQ64 devices. If you have purchased the devices from the authorize distributor or supplier, then those devices are authentic with the correct MPN : EPCQ64ASI16N.
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
Otherwise, Intel (Altera) do not ensure the device quality and do not provide the further service. Here is solution published for your reference:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd11102010_938.html
Nooraini
