Programmable Devices
21608 Discussions
LED diode as indicator that FPGA works
I want to put some led diode as indicator that my FPGA works fine ( I use ARRIA II GX ). Is there a pin I can use as indication that my component works and in user mode ?
PS -- I use JTAG configuration .
Thanks...
Look up the CONF_DONE or INIT_DONE pins in the handbook.
IIRC, these are dual purpose pins, which can otherwise be used as regular I/Os.
I know ,
But I do I put there LED so that it will "light" when the FPGA works when
it is already connected to resistor and VCCIO , and those pins are driven high
when the device ( === > no current passing) is on ?
Thanks for your quick reply ...
