21613 Discussions
LVDS Interface in Cyclone V 5CEBA7F27C8N
ShivaKi
1. In Cyclone V 5CEBA7F27C8N, if an IO pin is configured to operate as Output in 'LVDS IO Standard',
what will be the output drive current strength of that IO pin?
2. If LVDS IO standard is selected for a IO pin, FPGA considers operating the IO pin at 2.5V LVDS?
Note: In CycloneV Device Handbook Volume 1: Device Interfaces and Integration, in Table 5-25: Programmable Current Strength Settings for Cyclone V Devices, the LVDS I/O standard is not defined.
FvM
LVDS current strength is specified by the standard, standard value is 3.4 mA. Cyclone V datasheet specifies an Vod range which relates to 2.5 - 6 mA.
LVDS IO standard requires a bank VCCIO voltage of 2.5 V.
ShivaKi
Related to Question 1 response, for example, a FPGA IO pin(pair) to be used as LVDS Differential Transmitting signal purpose, What is the I/O Standard to be selected for this differential pair pins in Pin Planner Quartus Prime software?
Is it LVDS or SSTL-2 Class I ? Please confirm
AqidAyman_Intel
I think it should be LVDS chosen as the I/O Standard in the Pin Planner in that case.
ShivaKi
When LVDS I/O standard is chosen in pin planner, the drive strength field not showing any output current value. It is Blank.
Please confirm, whether the IO pin for LVDS Standard is configured as output, will the pin drive any current ?
AqidAyman_Intel
Yes, you are right.
There are no output current settings for LVDS IO standard. However, you could set the VOD for LVDS.
FvM
Programmable Cyclone V LVDS Vod (low, medium, high) relates to current strength. For full information, refer to IBIS files. You can plot output characteristics with a viewer.
AqidAyman_Intel
Yes, it is correct statement from @FvM. You can get the IBIS model for CYclone V from the link below:
https://www.intel.com/content/www/us/en/support/programmable/support-resources/board-layout/ibs-ibis-index.html
I hope the previous response was sufficient to help you proceed. As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
