Programmable Devices
21602 Discussions
LVDS TX as LVDS receiver in Cyclone V
Hello, In a new design I have to interface a few 8-channels ADCs to a Cyclone V GX C9F31.The ADCs use LVDS signaling at 240 MHz DDR.
In a previous design I've used Cyclone IV and any LVDS pair could be used for either output (true or emulated LVDS) or input.
Now for Cyclone V my understanding is that only the LVDS_RX can be used as receivers.
It this really the case?
Quartus II (13.1) fitter complains if I try to assign an input with LDVS io-standard to a LVDS_TX pair.
The Cyclone V handbook mention that the other way around is possible (use a RX pair as emulated TX) but no word for my case.
Many Thanks in advance
Yes, this really is the case. You will not be able to drive a differential signal into a DIFFIO_TX_xxx channel. Differential input signals will have to go into DIFFIO_RX_xxx pins.
Note: emulated LVDS does allow DIFFIO_RX_xxx pins to be driven.
Thanks for the information.
I'll have to use more banks for the ADC readout.
Nice to have deserializer in hardware thou.
As a comment, It would be helpful to have a list of the new features/limitations with respect to the previous device in the family (e.g. EPC5 vs. EPC4) in the Handbook.
