Programmable Devices
21599 Discussions
MAX 10 Projamming Issue 10M25SCE144I7G
INITDONE
Hello Team,
In one of our project , We are using Max 10 10M25SCE14417G device . On first Time , We able to Flash Device successfully without any Issue. Here I attached both working and non working screen shot.
But second time time on wards , We are getting the bellow error
Incompatible feature ID for Device 1 . Expected feature ID is 120 but fouL&42 126 Unrecognized device .
Exit code = 6 -- Unrecognized Device .
Here we are using JAM file and The same programming file only using all the time.
Can you please help me to resolve the Issue?
Thanks & Regards,
Ramesh S
Fakhrul
Hi INITDONE,
Have you tested it (the .jam file) on another Max 10 device? What's the behavior?
Try to make a new simple design, generate it into a .jam file, and try to configure it.
fakhrul
INITDONE
Hi Fakhrul,
Thanks for the Reply.
We have only one Max10 device is there  and made very simple design with 11 IO pins , just  loop test only.
Tried with SOF and POF and JAM  file but all file are showing same error and error is below,
Error(16353): Expected the Max 10 device at index 1 to be of type analog, but detected device of type compact instead. Ensure that you are using the correct programming file.
configuration scheme is Internal Configuration
Configuration mode : Single compressed Image (3200Kbits UFM)
still not able to resolve the Issue. Please help us
Thanks & Regards,
Ramesh S
Fakhrul
Hi INITDONE,
Have you try to program your .pof file using Quartus Programmer?
Is your .pof file able to program and load into FPGA (configure)?
INITDONE
Hi Fakhrul,
The issue is resolved once Dual configuration Intel FPGA IP is added into project.
Thanks & Regards,
Ramesh S.
Fakhrul
Hi INITDONE,
I’m glad that your question has been addressed, I now transition this thread to community support. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
