Programmable Devices
21611 讨论
MAX 10: a clock for SPI
名誉分销商 II
2,256 次查看
Is using an external clock without a clock buffer causing any problem?
I'm implementing SPI slave.
An external SPI clock is directly from a pin(not a clock pin, but just an IOpin) of the FPGA(10M08SAE144C8G).
Should I use a clock buffer for this?
The reason why I have this question is I got some timing violations.
Here are my simple codes.
always @(negedge sclk or posedge in_CSn)
if (in_CSn) Cnt <= 3'd7;
else if (Cnt == 3'd0) Cnt <= 3'd0;
else Cnt <= Cnt - 1'b1;
assign out_MISO = (~in_CSn)? pData[Cnt] : 1'b0;
And the timing violations are from "Cnt". These are very simple logics,
But I cannot understand why this causes timing violations.
Timing report shows this clock's restricted fMax is 250Mhz.
0 项奖励
4 回复数
名誉分销商 II
1,124 次查看
What speed are you trying to run your SPI at? An ordinary I/O pin should quite happily be able to operate as a clock for a small amount of logic.
Have you posted all the code driven by sclk? How have you constrained your design? If so then I suspect your constraints are not quite right. Add them to the post.
Cheers,
Alex
0 项奖励
名誉分销商 II
1,124 次查看
Thanks Alex for our reply!
- How have you constrained your design?
Not yet, cause I thought actual this SPI clock (sclk) is not that fast as less than 50 Mhz.
Please give me some hints. I recently moved from Xilinx to Altera.
I'm going to look at tutorial adding constraint file, but I'll be happy if you give me some tips making less mistakes.
0 项奖励
名誉分销商 II
1,124 次查看
Be careful, your design is not fully synchronous so it complicates the timing constraints.
You should not have in_CSn in your sensitivity list to be fully synchronous with the sclk signal, and in your case, you probably want to be synchronous with sclk.
--- Quote Start ---
--- Quote End ---
0 项奖励
名誉分销商 II
1,124 次查看
You have no timing constraints? What 'timing violations' are being reported?
What hardware are you using? Is the FPGA your a host talking to an external slave device?
You mention a 50MHz clock. What hardware are you using?
Assuming you are trying to talk to an external slave and you'd simply like to get something working I suggest you use the 50MHz clock to clock all your logic and treat your sclk as a signal (not a clock) that you generate with logic.
You are going to need more of a state machine to implement an SPI host as well.
JRL - whilst I agree this may not be ideally coded, the code does conform to the classic clock & (asynchronous) reset in the sensitivity list with a single conditional statement (if) handling the reset (in_CSn). So, I feel Quartus will have no trouble understanding this or timing it.
Cheers,
Alex
0 项奖励
回复
