20260 Discussions
MAX 10 pin status during startup and JTAG programming
StevenBE
What is the status of the IO pins during startup and JTAG programming?
Tristate?
I'm driving NMOS fets with the MAX10. I have to be 100% sure the FETs remain off during startup and programming.
Will a 100K pull-down be sufficient?
AnandRaj_S_Intel
  1. All I/Os pins are tri-stated until device into User- Mode.(It depends on the ICB Values)
  2. Yes, FETs remain off during startup and programming. Weak pullups are often fine for digital input. So you can use pull-up options.
  3. Each I/O pin provides an optional programmable pull-up resistor during user mode. The pull-up resistor, typically 25 kΩ, weakly holds the I/O to the VCCIO level.
Assignments-> Settings -> Compiler Settings -> Advanced Settings (Fitter) ->Weak Pull-Up Resistor option
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
StevenBE
I'm driving NMOS fets directly from the MAX10.
So for me tristate with an externall pull-down should work.
Is it also tristate during JTAG programming?
AnandRaj_S_Intel
Yes, You can use ​external pull-down.
I/O are tristate during JTAG programming.
Anand Raj Shankar
