Hi Guys,
I'm not sure how to add a pull up resistor for an input pin using Quartus Prime? I try to find it in Pin planner and assignment, but there is nothing shows to add a pull up resistor. Thanks!Link Copied
Right, the weak pull-up column need to be enabled before in the right mouse-button "customize columns" context menu.
You can also enable it using command as below in QSF file
set_instance_assignment -name WEAK_PULL_UP_RESISTOR ON -to * (This message was posted on behalf of Intel Corporation)- Mark as New
Thanks Guys! I found that option.
Topic Options
