21612 Discussions
MAX V add pull up resistor for input
Hi Guys,
I'm not sure how to add a pull up resistor for an input pin using Quartus Prime?
I try to find it in Pin planner and assignment, but there is nothing shows to add a pull up resistor.
Thanks!
Right, the weak pull-up column need to be enabled before in the right mouse-button "customize columns" context menu.
You can also enable it using command as below in QSF file
set_instance_assignment -name WEAK_PULL_UP_RESISTOR ON -to *
(This message was posted on behalf of Intel Corporation)
Thanks Guys! I found that option.
