21579 Discussions
MAX10 Boot Problem
EEren
On CFM0 - I have a boot image. With the boot I program a main image on CFM1.
First I switch to CFM0 with a micro controller pins
BOOT_SEL = 0
ENA = 0
Delay(100)
ENA = 1
Then I download the main image - main_0.rpd (with a big endian checkbox checked) .
After a successful image download I switch to CFM1
BOOT_SEL = 1
ENA = 0
Delay(100)
ENA = 1
And I see no response from FPGA.
What could be a problem? What do I miss?
The main image - should it include dual config module?
component dual_config is
port (
		avmm_rcv_address   : in  std_logic_vector(2 downto 0)  := (others => '0'); -- avalon.address
		avmm_rcv_read      : in  std_logic                     := '0';             --       .read
		avmm_rcv_writedata : in  std_logic_vector(31 downto 0) := (others => '0'); --       .writedata
		avmm_rcv_write     : in  std_logic                     := '0';             --       .write
		avmm_rcv_readdata  : out std_logic_vector(31 downto 0);                    --       .readdata
		clk                : in  std_logic                     := '0';             --    clk.clk
		nreset             : in  std_logic                     := '0'              -- nreset.reset_n
end component;
JohnT_Intel
Have you trigger reconfiguration? When you mention nothing happen is it still stuck in CFM0 image or it is stuck in configuring CFM1 image?
EEren
I mean it switched to CFM1 page but no reaction from the main program. It seems like CFM1 loaded OK - STATUS and CONF_DONE pins behave as expected.
To analyze the problem further I did the following - created a combined pof file
first page - boot.sof (CFM01)
second page - main.sof (CFM1)
Then I burn the pof file, switch to CFM1 - and no reaction from the main program.
When I burn the main.pof only - everything OK.
Oh...seems like my stupid mistake. Now it's OK.
JohnT_Intel
May I know how do you resolved the issue?
