Programmable Devices
21611 Discussions
MAX10 Dual Boot.
EEren
On CFM0 I have a bootloader. I create rpd file from a main project and burn it on CFM1.
After successful burning I switch BOOT_SELECT to boot from CFM1. However the main project
 failed to run and the boot runs.
Where can I find some instructions how to create valid rpd file and burn it into CFM1.
AnandRaj_S_Intel
Refer the links and demo projects.
AN 730: Nios II Processor Booting Methods in MAX 10 FPGA Devices
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/dualboot-design-example/
https://fpgawiki.intel.com/uploads/0/00/Using_Dual_Boot_MAX_10_Evaluation_Kit.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
EEren
I did as described in the document. However it dosen't work after programming prd file into CFM1. The master project should be configured as a single or a double image?
EEren
prd file is a binary file. should I reverse bytes before programming? and what is the order of bytes?
this
word_to_write = (UInt32)((reversed_byte[raw_data[i]] << 24) | (reversed_byte[raw_data[i + 1]] << 16) | (reversed_byte[raw_data[i + 2]] << 8) | reversed_byte[raw_data[i + 3]]);
or this
word_to_write = (UInt32)((reversed_byte[raw_data[i + 3]] << 24) | (reversed_byte[raw_data[i + 2]] << 16) | (reversed_byte[raw_data[i + 1]] << 8) | reversed_byte[raw_data[i]]);
EEren
May be I burn in the wrong sector? in my module flash_update generics are
SECTOR3_START_ADDR => 16384, SECTOR3_END_ADDR => 114687, SECTOR4_START_ADDR => 114688, SECTOR4_END_ADDR => 188415, SECTOR5_START_ADDR => 188416, SECTOR5_END_ADDR => 360447,
As I understood SECTOR5 is CFM0 and SECTOR3-SECTOR4 is CFM1.
AnandRaj_S_Intel
  1. Project related to dual configuration should be configured as  double image.
  2. Should I reverse bytes before programming? No.
For more information please check the below links.
https://www.youtube.com/watch?v=0k4AZmdW9Sk
https://www.youtube.com/watch?v=Z0l0GrjXn8w
Anand Raj Shankar
EEren
I write the rpd file. Let's take the first bytes from the file 50 FF 47 FF. But when I read it back from the flash I get FF 50 FF 47.
What's going on! Who can me explain for for Christ's sake!
AnandRaj_S_Intel
  1. Bit reversal is required if you have used little-Indian option while generating the .pof file. Which is default.
  2. If Big-Indian option is used bit reversal is not required
  3. Example design is attached
Anand Raj Shankar
EEren
Hi Anand
Thank you for the example.
I have something to clarify
for(address=CFM1StartAddress;address<=CFM1EndAddress;address=address+4) { scanf("%2x%2x%2x%2x",&receivedHex[0],&receivedHex[1],&receivedHex[2],&receivedHex[3]); /*Get 4 bytes from UART Terminal*/ for(byte=0; byte<4; byte++) { receivedHex[byte] = (((receivedHex[byte] & 0xaa)>>1)|((receivedHex[byte] & 0x55)<<1)); /*Swap LSB with MSB before write into CFM*/ receivedHex[byte] = (((receivedHex[byte] & 0xcc)>>2)|((receivedHex[byte] & 0x33)<<2)); receivedHex[byte] = (((receivedHex[byte] & 0xf0)>>4)|((receivedHex[byte] & 0x0f)<<4)); }   word = (receivedHex[0]<<24)|(receivedHex[1]<<16)|(receivedHex[2]<<8)|(receivedHex[3]); /*Combine 4 bytes to become 1 word before write operation*/ IOWR_32DIRECT(ONCHIP_FLASH_0_DATA_BASE, address, word); /*Command to write into On-Chip Flash IP*/ byte = 0; word = 0x0; while((IORD(ONCHIP_FLASH_0_CSR_BASE, 0) & 0x0b) == 0x02) { printf("Writing CFM1(%d)\n",address); } if((IORD(ONCHIP_FLASH_0_CSR_BASE, 0) & 0x0b) == 0x00) { printf("Write to %d failed\n", address); state=20; address = 700000; } if((IORD(ONCHIP_FLASH_0_CSR_BASE, 0) & 0x0b) == 0x08) {   }   }
This part
for(byte=0; byte<4; byte++) { /*Swap LSB with MSB before write into CFM*/ receivedHex[byte] = (((receivedHex[byte] & 0xaa)>>1)|((receivedHex[byte] & 0x55)<<1)); receivedHex[byte] = (((receivedHex[byte] & 0xcc)>>2)|((receivedHex[byte] & 0x33)<<2)); receivedHex[byte] = (((receivedHex[byte] & 0xf0)>>4)|((receivedHex[byte] & 0x0f)<<4)); }
I shouldn't do if I have Big-Indian option or I should swap MSB and LSB anyway?
AnandRaj_S_Intel
Yes, Shouldn't do if we have Big-Indian option​.
