21592 Discussions
MAX10 User-Specified ADC Logic Simulation Output
According the MAX 10 Analog to Digital Converter User guide:
"You can
configure the Altera Modular ADC or Altera Modular Dual ADC IP core to output user-specified
values in the logic simulation for each ADC channel except the TSD channel.If you enable this feature, you must provide a simulation stimulus input
file for each ADC channel thatyou enable. The logic simulation reads the input file for each channel and outputs the value of the currentsequence. Once the simulation reaches the end of the file, it repeats from the beginning of the sequence.
The
stimulus input file is a plain text file that contains two columns of numbers:• The first column of numbers is ignored by the simulation model. You can use any values that you wantsuch as time or sequence. The actual data sequencing is based on the text rows.
• The second column contains the voltage values."
Where can I enable this feature? I can not find this in the Qsys GUI. Does anybody know where to enable?
Hi Rene,
what is your Quartus Prime version? I think you need at least 16.0 to use this feature before it had not been supported.
Cheers,
fade
--- Quote Start ---
Hi Rene,
Cheers,
fade
--- Quote End ---
Hi fade, I'm using 15.1...so I will install 16.1 to see if the feature is available.
--- Quote Start ---
--- Quote End ---
Hi Fade, I installed version 16.1 and this fixed the issue. Thanks for your help!
