21615 Discussions
MAX10 initialization
Max10 devices don't have INIT_DONE pin to indicate initialization finished, How can I know the device goes into user mode?
thanks for your answer.
Still this question, just on page 30 of your datasheet link, I can see "The initialization sequence begins after the CONF_DONE pin goes high. Theinitialization clock source is from the internal oscillator and the Intel MAX 10 devicewill receive enough clock cycles for proper initialization." So my question is the initialization period.
--- Quote Start ---
The pin is called CONF_DONE on MAX 10:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/ug_m10_config.pdf[/QUOT
It is probably useful as you might be hoping,
Refer the “Internal Configuration Timing Parameter” from the below link,
https://www.altera.com/documentation/mcn1397700832153.html
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
I got it, thanks a lot!
