21615 Discussions
MAX3000A power consumption
I have a question about MAX3000A family power consumption. I have a EPM3064ATC44-10N full programmed (100% occupied) and working excellent @ 3V3. Without clock and all pins unconnected, I measured two devices: 30mA and 35mA so about 100mW.
Now in MAX3000A Device Family's datasheet pag.40 there is a chart which indicates at low clock rate (say DC) we can obtain under 20mA.
How can I program this CPLD to benefit 50% power reduction specified in datasheet? I'm not clear, there exists special Low Power versions? Or should I switch to other family ? (I need only 150KHz max. clock but lowest power posible since device will be portable).
Thanks for further suggestions,
"all pins unconnected" does this mean, also input pins are left floating ?
For a true "zero-power" solution, MAXII "Z" family or low static power CPLDs of other vendors should be considered.
I found! Was 'Auto Turbo Bit = Off' at fitter settings. Now I have ~50mW (~16mA) which I guess is maximum on this family. I'll check MaxII specs, tnx.
