Programmable Devices
21605 Discussions
MAX7000 Parallel Programming Specs.
I've been searching without success both Altera website & googleing for the parallel programing specs. for the MAX7000 devices. Anybody know where to get these? Any help would be appreciated.
What do you mean by parallel programming?
Non-JTAG programming.
--- Quote Start ---
--- Quote End ---
Yes, because MAX7000 do not have JTAG programming, only MAX7000S have JTAG programming. Also you need to use non JTAG mode if you want to re-enable the JTAG pins on MAX7000S devices where these have been used as I/O's.
This is normally done using the Altera Logic Programmer card or the Master Programming Unit (MPU).
