- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I need to touch an existing products and I should determine the size of the configuration EEPROM (of EPM7032) what I could not find in documentation. Could someone help me how/where can I find CPLD's configuration memory size?
thanks, gaborLink kopiert
4 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Gabor,
for CPLD devices is important to know a device internal structure such as macrocell count or logic array block count. EPM7032 consists of 32 macrocells and 2 logical array blocks. I would recommend to check the device datasheet and check Device Macrocell diagram as well as Device Block Diagram for EPM7032 device. Regards, Martin- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Martin,
I checked the DS again, but I could not locate any information about the configuration memory size of the macrocells, LA's or even on device level. I understand the structure and the modification works just fine, but (for SW) I should determine the possible max length of the configuration file (pof). So, I would restate my question in the following way: Is the size of pof file can vary based on the resource utilization of the CPLD? :) Thanks, gabor- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Gabor,
I have compared a couple of POF files generated by Altera MAX II/Quartus and targeting to the same device and some of them have different size. So the answer is yes, the size of a POF file can vary on the utilization but only slightly. I don't know the exact reason. FYI: The exact fuse count for the mentioned device of EPM7032 is 14672 as can be checked in the 3rd party device programmer software. Regards, Martin- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Martin!
I was expecting to find the device specific fuse count (or EEPROm size) in the datasheet, but your answer is covering everything I need now. Thanks a lot for your help! Best regards, gabor
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
