MAXII Code
Firefighter
Hi Intel,
I am reading some reference code for MAXII CPLD.  It is below. I do not understand what it is doing. Any one can help?
maxii_io
d_bit_13(.datain ( sck), //serial_clk_out
.oe (DC2026_DETECT), //DC2026_DETECT=1 SCK_33=sck & gated_sck, DC_2026_DETECT=0 SCK_33=HiZ
.padio (SCK_33), //pin to SCK of LTC2380-24
.combout (B13)); //
defparam d_bit_13.operation_mode = "bidir";
sstrell
This is an instantiation of a module named max_ii_io.  datain, oe, padio, and combout are the I/O of the module and sclk, DC2026_DETECT, SCK_33, and B13 are what they connect to in the current level of the design.  The defparam is sending a parameter value of "bidir" to a parameter named operation_mode in the instantiated module.
Firefighter
Hi Sstrell,
Thanks for your reply.
Is max_ii_io module a library or something that Quartus integrated, just like DFF? I tried to search it in the project verilog code, but could not find it. I also search it in the MAXII book. No luck.
Cheers
sstrell
Not a clue.  This is just standard Verilog code.  I don't know where you got it from or where you saw it.
Nurina
Did the above reply help?
Firefighter
Hi, Nurina and SStrell,
Thanks for help. It can be closed now.
Nurina
Glad your problem has been solved. I shall close the case now.
Nurina
