21615 Discussions
Max 10 Connect VCCA with VCCIO1A when Bank 1A used for ADC Only
TCWORLD
We have a board layout with minimal space available, and so I'm trying to minimise the component count in the design.
We are trying to use a 10M04SAM156 device and will be using the ADC feature. I understand that it is desireable to filter the analogue supplies (VCCA) as well as the VCCIO1A supply to minimise noise.
If we intend to use IO Bank 1A as analogue inputs only, and not as a digital IO, is there any downside to connecting VCCIO1A directly to VCCA? That way only one filter would be required (from the 3.3V digital supply to the VCCA analogue supply).
EngWei_O_Intel
Hi Thomas
Thanks for your inquiry.
If we refer to Example 5 and Figure 5 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf
it is not recommended to share VCCA and VCCIO1A/B as VCCA is powering analog part and is sensitive to noise.
Eng Wei
EngWei_O_Intel
Hi Thomas
We do not receive any response from you to the previous reply that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
