Programmable Devices
21594 Discussions
Max 10 FPGA Dev Kit, Windows 7 or 10?
SShaw4
Thanks for some previous help.
The readme.txt file in   c:\altera\13.1\kits\Max10M50    tells me to have the following:
Software Requirements
Demo applications installed with the Development Kit require the installation
of Quartus II v15.0.0/145 and are supported on the following operating systems:
* Windows 7 (64 and 32 bit)
* Windows XP SP2 (64 and 32 bit)
* Windows XP Pro X64 Edition
Therefore I ought to load version 15 of Quartus II Web.
My company issued laptop has Windows 10 Enterprise.  Is this a problem, or could I get away with hit.
Thanks for any help.
Scott S.
FvM
Not sure if the demo applications actually don't work with recent Quartus versions, e.g. 21.1, but I can tell that I'm running Quartus 9 and 13.1 under Windows 10 without any problem.
Frank
ak6dn
Valued Contributor III
I run Quartus II Web 13.0sp1, and Quartus Prime Lite 16.0 and 21.1 all on Windows 10 Pro 21H2 64b release. They run just fine no issues. I previously ran 13.0sp1 and 16.0 on Windows 7 Pro 64b.
Unfortunately you will find version 15.0 is no longer accessible via the download page.
Aside from 13.0sp1/13.1, the other versions now available are 17.0 thru 21.1.
RichardTanSY_Altera
You should be able to run the Quartus software (even 13.1) in Window 10.
Richard Tan
RichardTanSY_Altera
I have yet to receive any response from you in regards to my last reply.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos and select the best solution.
SShaw4
Thank you Richard.
Sorry I'm late with this.
Again, thanks.
Scott S.
