21611 Discussions
Max V SEU mitigation
Randrian
Dear Sirs,
I plan to use MAX V CPLD for an application exposed to ionizing radiation.
Do you have any papers about MAX V SEU testing and results, for both CRAM (configuration RAM) and CFM (configuration flash memory)?
Does the device implement SEU mitigation like CRC or someting else? I will not use TMR (triple modular redundancy) technique.
Randrian
lixy
Hi Randrian,
Here's currently no documentation for MAX V SEU mitigation. Also, CRC is not used in MAX V.
If you would like to know the FIT rate for MAX V device, you can log in Resource & Documentation Center (intel.com) with NDA and search for "Reliability Monitoring" report.
Also, there is an "SEU FIT Report" in Quartus, which is license-required .
Thanks & Regards,
Xiaoyan
Randrian
Hi Xiaoyan,
For my design, I will replace a MAX II-based old design by MAX V. Could you please confirm if the FIT rate of MAX V device is the same as the FIT of MAX II?
Alexandre
lixy
Hi Randrian,
Yes. MAX V and MAX II used the same process technology, so the FIT rates are the same.
Xiaoyan
lixy
Hi Randrian,
Any further questions?
Xiaoyan
Randrian
Hi Xiaoyan,
What about the flash data retention, how many years for 12hours use per day?
Alexandre
lixy
Hi Alexandre,
Sorry I could not find this data you mentioned.
There's only "Erase and reprogram cycles" listed in MAX V Datasheet and the reliability monitoring report.
Thanks & Regards,
Xiaoyan
Randrian
Hi Xiaoyan,
Could you tell me if the data retention should be the same as Max II?
Alexandre
WZ2
Hi Alexandre.
I just further checked documentations.
The estimated Data Retention hours for MAX II and MAX V are the same, because they used the same FLASH memory process technology.
Thanks & Regards,
