21611 Discussions
Max10 Programming with daul boot image
Evan_shih
Dear Intel
I've compiled my project which has dual compressed image in it.
Also import two different .sof (07 and 08)  in Page0 and Page1 respectively to convert an .pof file.
While I select the  CFM0 only under Program/Configure in programmer tools , is it only programs Page0's image or it programs Page0 and Page1 in CFM0 at the same time?
Thanks!
Fakhrul
Please be advised that due to the absence of a response from you regarding the previous notification we provided, we will be transitioning this thread to community support. If you have any new questions or concerns, we kindly suggest opening a new thread to receive assistance from Intel experts. However, if you do not have any further inquiries, the community users will be available to assist you on this thread. Thank you for your understanding.
Fakhrul
Hi Evan_shih,
Only Image 0 will be programmed if you check the CFM0. Unless you check for both CFM0 and CFM1. Kindly refer to the following table
from Intel® MAX® 10 FPGA Configuration User Guide
Fakhrul
Evan_shih
Dear Fakhrul
As you metion , Only Image 0 will be programmed if I check the CFM0.
There is another question ,  what is Image 0 stands for ?
Is it stands for an .pof which convert by two .sof (07 and 08 ) or it stands for an sof ( 07 ) only ?
Thanks for your relay.
Evan
FvM
you definitely should review the above mentioned configuration user guide. It clarifies about flash memory utilisation in dual boot configuration. CFM1 in Quartus Programmer stands for CFM1 + CFM2.
Page0/CFM0 is usually the factory image in a RSU configuration, Page1/CFM1 the application image.
Frank
Evan_shih
Dear Frank
Thanks for your reply.
Yes, I've study the configuration user guide already.
According to Onchip flash IP setting on my design to compare the table you post and also the user guilde's change list the Image 2 should stands for CFM1 and Image1 should stands for CFM0 , right ?
Here is the question , if I only select CFM0 under Program/Configure in programming tool. It should be programmed image0(Page0) into the Flash.
While I earsed the CFM0 by programming tool it should not have any logic implement in next AC power on.
But result shows Image1(Page1)  instead.
It was confused me that is only Image1( Page1) 's sof exist in CFM1 ?
P.S. I've eraserd CFM0/CFM1/UFM before programming CFM0 only .
Thanks!
Evan.
Fakhrul
Hi Evan_shih,
My apologies as I have overlooked your comment. Yes, you are right,  if CFM0 is erased, the FPGA will attempt to load the configuration from CFM1 (image 1) instead.
Fakhrul
Fakhrul
