Programmable Devices
21602 Discussions
Motor on DEO Board
Contributeur émérite II
1 359 Visites
Can I use dc motor on DEO Board on the GPIO pins?
0 Compliments
3 Réponses
535 Visites
--- Quote Start ---
--- Quote End ---
Do you mean directly connect a DC motor to the FPGA pins? NO, that is almost certainly not possible, unless it is a very small low power motor.
So what you will need is some type of a motor driver board; usually they have two or four reasonably high current capable MOSFET devices.
0 Compliments
535 Visites
Well - additionally to the power issue, motors are inductive elements. Thus even if the power would be enough to drive the Motor, I doubt the I/O Pins will deal with the voltage rise on power OFF...
0 Compliments
535 Visites
I have used a motor on a de2-115, but just to be sure I added a motor driver board (H-bridge) in between. If you search for motor+arduino you can find a number of these.
0 Compliments
Répondre
