1 解答
Hi Galio,
Thanks for this question. As I understood , you have edited the BSP settings and then you see the following error (correct if I am wrong):
make all
Makefile not up to date.
settings.bsp has been modified since the BSP Makefile was generated.
Generate the BSP to update the Makefile, and then build again.
To generate from Eclipse:
1. Right-click the BSP project.
2. In the Nios II Menu, click Generate BSP.
To generate from the command line:
nios2-bsp-generate-files --settings=<settings file> --bsp-dir=<target bsp files directory>
make: *** [makefile] Error 1
Please follow the instruction given. If you still see the same error, Please do the following:
1- Open the BSP project folder
2- Right click the Makefile>> Delete
3- Open the NIOS II Command Shill
4- Write the following commands:
cd <...../project_bsp>
nios2-bsp-generate-files --settings=settings.bsp --bsp-dir=<C:/…./<project_bsp/>
5- Build your project again.
Embedded guy
链接已复制
3 回复数
Hi Galio,
make all
Embedded guy
