21615 Discussions
NOR flash read write problem
Hi all experts
I have a problem with NOR flash when it reads and writes.
Here is my parameters
Arria10 (with quartus prime standard edition)
Micron Serial NOR flash 1.8V (MT25QU01GBB
(There is limited images I can post, so I will put the link on reply)
Msel = 010 (hard wired) as below
epcq_controller in qsys was set as below
https://alteraforum.com/forum/attachment.php?attachmentid=14251&stc=1
("STANDARD" & "QUAD" both cases were tried)
devices & pin option was set as below
https://alteraforum.com/forum/attachment.php?attachmentid=14253&stc=1
(I also tried "AUTO" for "EPCQL1024" & "1.8V" in configuration device)
When I tried to write .sof image into flash by using "NIOS II Flash Programmer"
Error message pops up as below
https://alteraforum.com/forum/attachment.php?attachmentid=14254&stc=1
Do you have any idea or any suggestion for this issue?
To debug this issue, read & write test was performed by using Memory Test template
Here is my result of Memory Test template (below)
https://alteraforum.com/forum/attachment.php?attachmentid=14255&stc=1
If you have any idea or any suggestion, I appreciate your help.
Thank you for reading
