21615 Discussions
Need ODC, POPs and Material Declaration data
HK15
Need ODC, POPs and Material Declaration data for EPCQ4ASI8N
NazrulNaim_Intel
Sorry for the delay. For information needed as requested, it can be accessed through the link below.
Link : https://cdrdv2.intel.com/v1/dl/getContent/693190?fileName=EPCQ4ASI8N_20191201100637_v1.xml
Below is the step how to open XML file in Excel
  1. Open a new blank Excel file
  2. Click on Developer tab, then click Import
  3. Select the xml file you want to import, then click Import
  4. Click "OK" on pop-op information, and also "OK" on where to Import data
  5. The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
  6. I recommend to delete column AK so that the other columns will display better:
Hope that helps.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
