21608 Discussions
Need help deciphering date and facotry codes
I am trying to find information figureing out what the top and bottom markings on an Altera MAX EPM7256ATI144-10 mean. I have searched the Altera website but i could not find much information on product marking. I am particulary intereseted in the meaning of the bottom side markings. My parts are marked on the bottom with:
VAC273336
0037 A N
I would like to know what this means and if possible if it contains a date code and place of manufacture.
Assuming standard dating format is used, 0037 may be the date code. It means year 2000, week 37 (Septemberish...)
Thanks. I'm trying to find an official altera document stating what the bottom side markings mean. If the 0037 is a date code, then it does not correspond to the date code on the top of the part. We recieved this parts and are suspicious of their origins. I would like to ind out exactly what they are, and if they have been relabeled or tampered with, I want to find definitive proof. The markings on my parts are as follows:
top
ALTERA
MAX
EPM7256ATI144-10
T CAC270743A
VAC2732532
301TA7VAQ
bottom
VAC273336
0037 A N
not sure if its published or not, but its kind of a double edged sword publishing that kind of information. once the counterfeiters have the same data they can print the correct lot codes on the fake parts.
you might ask Altera (or your distributor) directly in an SR if those are legal date codes
