Nios II Problem!
Hi Sir/Madam,
Actually I am finding one problem in my design that after fusing the .sof files when I run software the processor get paused.
This problem comes most of the time when I enable the signal tap. When the signal tap is disabled the software runs properly. what comes in console window of Nios II is as given below.
I will be thankful for your kind sugestion.
Have a nice day!
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x00C10C60: verified
Initializing CPU cache (if present)
OK
Downloading 00800020 ( 0%)
Downloaded 63KB in 0.7s (90.0KB/s)
Verifying 00800020 ( 0%)
Verify failed between address 0x800020 and 0x80F89F
Leaving target processor paused.
Regards:
SB Yadav
mostly if all elecric connections ar correct, this is a timing issue
is your memory at 0x80xxxx an external memory (i assume yes due to the memory size)
do you use sdram ? if yes, have you cecked that the phase shift of the sdramclock is correct ?
have you checked your timing ? do you get timing warnings ?
