Nios ii de2
I am a beginner and NOSII Quartus I operate Altera DE2, I wanted to use the SD card (memory card from my Altera DE2) board for a project.
after sending the architecture of the example that comes with the CD named DE2_SD_Card_Audio, I encountered a problem while sending the executable file (. sof), and here is the error message that is displayed "launching XXX2013Nios II Hardware configuration has Encountered a problem. Elf downloading process failed". Another alternative display shows that there is a problem between address "Verifying failed 0X6000000 address and 0X600FFFF Between", these addresses correspond to memory addresses 2 (RAM U2).
and this is the complete downloading messages:
"Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x09405178:
ID value verified
Timestamp value does not match: image on board is older than expected
Read timestamp 3:10:26 2009/11/04; expected 12:30:59 2012/12/02
Warning: The software you are downloading may not run on the system which
is currently configured into the device.
Initializing CPU cache (if present)
OK
Downloading 04000000 ( 0%)
Downloading 06000000 ( 0%)
Downloading 06010000 (66%)
Downloaded 97KB in 1.6s (60.6KB/s)
Verifying 04000000 ( 0%)
Verifying 06000000 ( 0%)
Verify failed between address 0x6000000 and 0x600FFFF
Leaving target processor paused"
As i notice there is a Warning, is this warning mean that there is a problem in my Hardware archiecture vs software definitions, or there is something that i can't undrestand.
NB: the file. Sof that comes with the example works fine, but when I compile the example and brings ALTERA gives me another SOF File. Sof gives the problem mentioned before.
Please help friends.
