21607 Discussions
OneAPI Devcloud FPGA hardware issues (stratix10 node) (Invalid Binary)
Wei-Chih
Hello support team
When I used qsub -l nodes=1:fpga_runtime:stratix10:ppn=2 -d . run_fpga_hw.sh command to run my code on devcloud stratix10, it get the error as below:
terminate called after throwing an instance of 'cl::sycl::runtime_error'
what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
make: *** [run_hw] Aborted
After I search this issue of devcloud stratix10, it might relate to FPGA Board Initialization, right? According to https://community.intel.com/t5/Intel-DevCloud/Invalid-Binary-for-FPGA-Stratix-10-Nodes/m-p/1300748#M2604  and   https://www.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/programming-interface/fpga-flow/fpga-bsps-and-boards/fpga-board-initialization.html
it seems i need to do Initialization if i want to use stratix10. if my understanding is right, can you teach me how to modify my makefile.fpga ? if not, please tell me how to solve it.
below is my makefile.fpga content, can you teach me how to add stratix initialization into my  makefile.fpga
CXX := dpcpp
CXXFLAGS = -O2 -g -std=c++17
SRC := kernel.cpp
.PHONY: fpga_emu run_emu clean
fpga_emu: kernel.fpga_emu
hw: kernel.fpga
report: kernel_report.a
kernel.fpga_emu: $(SRC)
$(CXX) $(CXXFLAGS) -fintelfpga $^ -o $@ -DFPGA_EMULATOR=1
a.o: $(SRC)
$(CXX) $(CXXFLAGS) -fintelfpga -c $^ -o $@ -DFPGA=1
kernel.fpga: a.o
$(CXX) $(CXXFLAGS) -fintelfpga $^ -o $@ -Xshardware
run_emu: kernel.fpga_emu
./kernel.fpga_emu
run_hw: kernel.fpga
./kernel.fpga
dev.o: $(SRC)
kernel_report.a: dev.o
$(CXX) $(CXXFLAGS) -fintelfpga -fsycl-link $^ -o $@ -Xshardware
clean:
rm -rf *.o *.d *.out *.mon *.emu *.aocr *.aoco *.prj *.fpga_emu *.fpga_emu_buffers kernel.fpga *.a
hareesh
Hi Wei-Chih,
We found two issues with your name but different case numbers.
  1. OneAPI Devcloud FPGA hardware issues (stratix 10 node) (Invalid Binary)
  2. DecCloud FPGA hardware issues
Can you please confirm to me that both are the same issues or different?
and please share your code.
thanks,
Wei-Chih
Hi hareesh
right, they are same issues, but a little different. In the beginning both arria10 and stratix10 have -42 (CL_INVALID_BINARY)  error, but after i tried modified work group size(decrease), I found arria10 can run with slow execution time. However,  stratix10 was still fail in any conditions. Could you help check this issue?
attached is my code
By the way, I have another question. In my code, if i want to modify lambda function from h.parallel_for to h.single_task, can you teach how to modify it? Cause i wanna run it on fpga hw.
If it can be modified to h.single_task, I need to use nd_item<1> class, but it seems h.single_task cannot pass parameter. So how can i modify it?
hareesh
HI @Wei-Chih,
Did you tried this
BSP loaded on device was pac_s10_usm, designs compiled for pac_s10.
To switch BSPs:
aocl initialize acl0 pac_s10_usm or
then also you getting same problem.
