21604 Discussions
PCN1817 Qualification data
ENg2
As stated in the PCN1817, the qual data was originally not available until mid-Mar 2019 when the PCN was published last year.
I would require the qual report for Penang, Malaysia for Stratix 10.
Pls kindly help to send me a copy. Thanks.
ChiaLing_T_Intel
Hi Eric, Thank you for contacting Intel Community. Please allow me to further clarify with the Intel internal team. Thank you Regards, Chia Ling
ChiaLing_T_Intel
Hi Eric, Please be noted that the engineering is in progress to update the PCN1817 qual results. In the meantime, I would like to share the test results with you which applicable to Table 3 - Test result = 0/230 Thank you Regards, Chia Ling
