Programmable Devices
21579 Discussions
Power Delivery Network tool says I need very few capacitors.
BVola
Débutant
1 805 Visites
Running PDN for Cyclone IV results show only 4 capacitors required, based on results from EPE. I can even change current to 1 amp and it still only requires 5 caps. Is this right? PDN attached.
0 Compliments
8 Réponses
ak6dn
Précieux contributeur III
1 727 Visites
Your power rail currents range from 10mA(min) to 40mA(max) in the spreadsheet.These are extraordinarily low numbers and very likely incorrect.
0 Compliments
BVola
Débutant
1 727 Visites
Everything came right from the power estimator; I was also a little surprised at how low the core current was. I revisited my power calculation, and I changed the I/O load capacitance. It's not clear if the load capacitance column in the power estimator is TOTAL capacitance or capacitance-per-pin. I initially assumed that it was per pin. I changed it to total, which gave me 1300pF (130 pins), which caused the current to jump to about 900 mA. Still, changing that number had very little effect on number of capacitors. And, as I mentioned, I can just arbitrarily put high current values into the PDN tool and still get very few capacitors.
(Full disclosure: I cheated and lumped all my I/O into one module; that shouldn't make a difference).
0 Compliments
ak6dn
1 727 Visites
You have no entry for your core clock frequency. Power to the core will vary dramatically with frequency and % utilization.
Same for I/O power. Static load is not as much a determining factor as is dynamic I/O switching frequency.
0 Compliments
BVola
Débutant
1 727 Visites
The power estimator uses the clock frequency to calculate dynamic power, so that's already accounted for. Further, the Core Clock field is "N/A", and can't be changed (the popup note indicates that you need to be in "custom mode" to enter that. Not even sure HOW to enter custom mode).
0 Compliments
ak6dn
1 727 Visites
Well in that case I don't believe the spreadsheet at all. A 1.2V Vcore at 20mA and a recommended 5ohm target impedance for the power rail are completely unrealistic values. I don't know what inputs you fed into Quartus to generate this spreadsheet but I would go back to the source. Something in your core and I/O clock setup is not correct.
0 Compliments
SreekumarR_G_Intel
1 727 Visites
can i know you guys facing still issue the same issue ?
0 Compliments
BVola
Débutant
1 727 Visites
Nothing has changed. Do I trust the power estimator? Do I trust the PDN tool?
0 Compliments
YuanLi_S_Intel
Employé
1 508 Visites
This thread will be transitioned to community support. If your question is not addressed yet or you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
0 Compliments
Répondre
