Programmable Devices
Primitive
So i am currently converting some of our companies work done on Xilinx FPGA to a Altera FPGA. I have been working on it for a few mounth so far with litlle to no problem. But All i really had to do is change a few FIFO and other cores that was xillinx specific. But now i have come acress a Xilinx primitive that i don't know how to change. In Xilinx the Primitive is Call IDDR2. I am trying to find a similar Core but i am not sure witch or where to find it. So i dug up a litlle on this IDDR2 Primitive and here is what i found:
- From what i understand the IDDR2 block is used to acess a ILOGIC2 primitive
Table 2-2: IDDR2 Port Signals
Port Name Function Description
D Input Data input
C0 Input Clock input, optionally invertible
C1 Input Second clock input having 180° phase difference relative to C0,
CE Input Clock enable
R Input Reset. Software will issue an error if both R and S are connected
S Input Set. Software will issue an error if both R and S are connected
Q0 and Q1 Output Data outputs
I added some pictures that might help understand the primitive.
here is a link to the data sheet of the xilinx primitive where the IDDR2 is explained:
http://www.xilinx.com/support/documentation/user_guides/ug381.pdf
Any help or advice would be great
For input DDR, use altddr_in. It's not the same, i.e. you only feed it one clock and it automatically hooks up the rising and falling edge. It usually also latches the data on the falling edge before registering it on the rising, so both upper and lower bits are presented to the fabric in parallel on the rising edge of the clock. You might not have the control signals either, but I've never seen that be a problem.
Thanks. i used that IP core and it seems to work properly.
