21611 Discussions
Problem simulating FIFO at Modelsim
Hello i used the FIFO from megawizard and i can't simulate it at modelsim, i am trying to add the altera_mf library but all my tries are worthless..
please help! This is my error
vsim work.tb_fifo# vsim work.tb_fifo # Loading work.tb_fifo# Loading work.fifowrapper# ** Warning: (vsim-3009) - Module 'fifowrapper' does not have a `timescale directive in effect, but previous modules do.# Region: /tb_fifo/u0# Loading work.base# ** Error: (vsim-3033) C:/DHW/Projetos/dmafifo/base.v(82): Instantiation of 'dcfifo' failed. The design unit was not found.# Region: /tb_fifo/u0/fifo_inst# Searched libraries:# C:\DHW\Projetos\dmafifo\tb\work# Error loading design
did you compile altera_mf into altera_mf or into work?
these docs should help:
http://www.altera.com/literature/hb/qts/qts_qii53001.pdf
http://www.altera.com/literature/hb/qts/qts_qii53025.pdf
you must not be using ModelSim-A(S)E?
yes i am using modelsim ASE.. it is possible?
I didnt compile them into work, can you tell me how? Going to read the docs you told me to. Thanks
ModelSim-ASE should have the altera_mf libraries precompiled and installed. however, from your simulation:
# Searched libraries: # C:\DHW\Projetos\dmafifo\tb\work
it doesn't look like it is searching through all of the Altera libraries. in ModelSim's Libraries window, do you see just the work library or a list of various libraries?
i see all the libraries there but i can't make modelsim search theree
Hello ? = )
if you post some HDL i'll try and take a look. you can just isolate it to the test bench and FIFO
What kind of HDL you mean?
module fifowrapper( // inputs: rdclk, rstn, rdreq, // outputs: valid, q ); input rdclk; input rdreq; input rstn; reg rdreqtemp; reg wrclk; reg wrreq; output q; output reg valid; wire data; reg data_in; assign data = data_in; wire usedw; reg contador; reg delay; always@(posedge rdclk or negedge rstn) if (~rstn) begin valid <= 0; contador <= 0; data_in <= 0; wrreq <= 0; delay <= 0; end else begin contador <= contador +1; valid <= 0; wrreq <= 0; if(usedw == 6'b100000) begin valid <= 1; end if(contador == 100000000) begin wrreq <=1; data_in <= data_in + 32'b00000000000000000000000000000001; contador <= 0; end end base fifo_inst ( .data ( data ), .rdclk ( rdclk ), .rdreq ( rdreq ), .wrclk ( rdclk ), .wrreq ( wrreq ), .q ( q ), // .rdempty ( rdempty_sig ), // .rdusedw ( usedw ) .wrusedw ( usedw ) // .wrfull ( wrfull_sig ) ); endmodule
This is my wrapper
and this if my testbench
`timescale 1 ns/1 ns module tb_fifo; parameter P_CLKPERIOD = 50; reg tb_i_clk; reg tb_i_rstn; wire tb_valor; //CLOCK DO SISTEMA EM 50ns - 20Mhz initial tb_i_clk = 1'b1; always# (P_CLKPERIOD/2) tb_i_clk <= ~tb_i_clk; // RESET DO SISTEMA initial begin @(posedge tb_i_clk); tb_i_rstn <= 0; # 10; @(posedge tb_i_clk); tb_i_rstn <= 1; end // BLOCO PRINCIPAL fifowrapper u0( .rdclk (tb_i_clk), .rstn (tb_i_rstn), // outputs: .valid(tb_valor) //.q ); endmodule
can you post base.v too?
my base.v is the fifo itself made from megawizard
